Spot03831.pngChanging the label legend
As lighting devices are placed on the light plot, the active label legend is assigned to them by default. However, the legend can be changed for a selection of lighting devices.
Command
Path
Assign Legend to Lighting Devices
Spotlight > Label Legend
Context menu
To change the lighting device label legend:
Select one or more lighting devices.
Select the command.
The Assign Legend to Lighting Devices dialog box opens.
Select the new label legend for the lighting devices.
The label legend can also be changed for an individual lighting device or accessory by selecting the device, and then selecting the legend name from the Use Legend list in the Object Info palette.
Use the Find and Modify command to quickly generate a custom selection of specific lighting devices and apply the new legend to the selected devices (see Find and modify).
Changing the label legend properties of a selection
Command
Path
Assign Legend properties to selected
Context menu
The 2D and 3D label legend properties from one lighting device can be copied to a selection of lighting devices, or all of the label legend properties can be changed for all selected lighting devices. This is a convenient way of obtaining a consistent label appearance for a selection of lighting devices. The changes include the position of 2D and/or 3D single label layouts, 3D label view selection, and the flipping of 2D and/or 3D label text.
To copy the label legend location properties to a selection:
Right-click on a lighting device with the desired label positions and properties, and select the command.
The Assign Legend properties to selected dialog box opens. The parameters are initially set to those of the lighting device that was clicked upon.
Parameter
Description
Assign View
When the label legend includes 3D labels, select the view for the labels when displaying the drawing in a 3D view
Assign 2D Location/Assign 3D Location
(single label layout only)
Displays the label text box position relative to the clicked lighting device; this allows the label to appear in consistent locations for all selected lighting devices
Assign 2D Flipping
Flip Front & Back 2D Legend
Mirrors the label legend along the X axis of the lighting device (a label legend that displays in front of the lighting device displays behind it instead)
Flip Left & Right 2D Legend
Mirrors the label legend along the Y axis of the lighting device (a label legend that displays to the right of the lighting device displays on the left instead)
Assign 3D Flipping
Flip Top & Bottom 3D Legend
Mirrors the 3D label along the X axis of the lighting device (for example, a label legend that displays at the top of the lighting device displays on the bottom instead)
Flip Left & Right 3D Legend
Mirrors the 3D label along the Y axis of the lighting device (for example, a label legend that displays to the right of the lighting device displays on the left instead)
Rotate 3D Legend with Z Rotation
Matches the 3D label legend views with the lighting device’s rotation
Simply click OK to apply the desired label properties to the selection, or make changes and then click OK to apply changes to the entire selection.
Label Legend Manager
Lighting device properties
Adding lighting devices
